pal progressive scan
Discussion in 'Blu-ray & DVD Players & Recorders' started by noyce, Nov 23, 2003.
  1. noyce
    noyce
    Aug 10, 2003
    179
    16
    England
    I have just recieved my panasonic ptae300 projector and have connected my US Xbox to it using a high definition pack and am amazed what a difference progressive scan makes. So here comes my question, i am looking for a dvd player that is capable of progressive scan but i don't really want to spend anymore than about £500 (less if possible). Also, as my Xbox is connected using the component leads so will a DVD player still output in PAL progressive through the RGB scart connection or would i have to use the component connections?
    Any help very much appreciated
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    You won't be able to get PS from the Scart - component only, I'm afraid.
    Steve
  3. mjcairney
    mjcairney
    Oct 26, 2003
    7,143
    2
    2
    137
    Airdrie, Scotland
    +991
    The Sony DVPNS730 does PAL/NTSC Progressive Scan and is not too expensive - in fact I'm sure you can get it for quite a bit under £200.
  4. chrissandgate
    chrissandgate
    so does the Yamaha sd540, andits around £100. Its had a couple of reviews in the mags on sale at the moment, I think What Video and TV gave it 5 stars and DVD Reviewer gave it a grouptest winner award.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    HK DVD 25 and 30 are NTSC & PAL PS there are couple on the classifieds at the moment but can both be found for less than £500 will need YUV inputs but a switcher is not too much or the perfect reason to upgrade to an AV amp with component switching ie Denon 3803 HK AVR4550 Marantz SR7300 or similar.
  6. joflo
    joflo
    Dec 8, 2003
    27
    Hornydragon,
    Can you confirm DTS 96/24 on HK4550 ?
    Thanks,
    Joflo
