PAL Progressive Scan Question
Discussion in 'General TV Discussions Forum' started by antz, Sep 30, 2003.
  1. antz
    antz
    Aug 13, 2003
    335
    Brum
    +8
    Are there any Widescreen CRT Televisions that support PAL progressive scan?
    I'm in the market for a 32" widescreen and figure I may as well make sure it has this feature...probably more so than being 100Hz.
    The spec on the Toshiba PF2's state that they have 'progressive scan'...but it's not clear to me if they accept a PAL progressive signal from a Pal Progressive DVD player.
    All help is appreciated....this is my treat for Xmas
    Best Regards
    Antz:D
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,433
    United Kingdom
    +1,803
    The JVC HV32D25 accepts both PAL & NTSC Progressive. Pretty sure the Toshiba PF2 range does as well.
  3. leeb
    leeb
    Jan 10, 2003
    880
    28
    Melton Mowbray
    +52
    Yes to the Tosh PF2, and of course the Panny PD30. As to which one of these to get; I'm not going there! :zonked:
