PAL Progressive Scan Player/Recorder?
Discussion in 'Blu-ray & DVD Players & Recorders' started by pedromartinez, Feb 20, 2003.
  1. pedromartinez
    pedromartinez
    Having read one of the other threads in this forum, I was taken to the following link:
    www.hivizone.com
    I noticed this site is advertising the Philips DVDR-890 as a PAL & NTSC Progressive Scan DVD Player/Recorder!
    Is this accurate or have they got it wrong? If its true, this could be exactly what I have been looking for, I was about to buy ther 963sa but the added benefit of recording would sway my choice.
    Any advice on this product compared to the 963sa would be much appreciated.
    thanks:confused:
  2. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    No it's not true. There is a philips dvd recorder that supports PAL & NTSC progressive scan, and it's the 1000MKII model I think. Although it doesn't provide the de-interlaced images via component video outputs - which is odd - I think it uses a BNC interconnect. only useful if you've a projector or plasma
  3. IanM
    IanM
    Dec 17, 2002
    158
    +5
    I think that the DVDR1000 MkII uses a 15-pin DSUB output for progressive scan output, like those used to connect computers to monitors.
    I couldn't find out if this model had the DCDi chip in it (like the MkI) so I went for the cheaper 963sa player instead, and decided to wait until recorders come down in price and up in playback quality.
    Cheers,
    Ian.
  4. Y.Y.Yu
    Y.Y.Yu
    Dec 11, 2002
    2
    Happy Valley
    I live in Hong Kong .The H.K. version of DVDR-890 can output PAL /
    NTSC progressive signel .That's been printed in the catalog .
    Y.Y.Yu
