PAL progressive + RGB scart + <£500 ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Luc, Apr 7, 2002.
  1. Luc
    Luc
    Aug 7, 2000
    420
    I'm looking to upgrade my Pioneer 626-D, but want something that'll do progressive PAL when i upgrade my projector, which is next on the list. But my TV doesn't do s-video, so i also need one that's got RGB scart outs too. Are there any out there, all the PAL progressive ones i can find (native or hacked like these > https://www2.setssl.com/~hivizone/dvdplayer/main_frame.htm ) seem like asian/european models without scarts. Are there any that do what i want and won't cost £1000 ?
  2. tahustvedt
    tahustvedt
    Feb 11, 2002
    112
    19
    In a galaxy far, far away... (Norway)
    The Denon DVD-2800 will do all of the above after hacking the firmware. I have a DVD-2800 which has enabled 576p and it's great! The SCART-RGB picture on my TV is also great! It costs around £500 in Norway and shouldn't be more expensive in the UK. :)
    There are a few new models arriving in a moment so you might want to wait a few weeks before you decide. The new models from Denon are DVD-2800 MK2 and DVD-3800.
    Tor Arne
