Pal Progressive HK25
Discussion in 'Blu-ray & DVD Players & Recorders' started by NicH, Mar 10, 2003.
  1. NicH
    NicH
    I've just connected up my new HK DVD25 to my new Toshiba Plasma, but have a stupid question.
    I was told that the player had been Pal Prog hacked (it is certainly multi-region), but my question is how can I tell if it is Pal Prog?
    I ask because when I select Progressive in the menu, the picture type comes up as NTSC and this is greyed out ie it can't be altered.
    Thanks for your help
    Nic
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
  3. Big_AL007
    Big_AL007
    You do not havethe correct firmware for PAL progressive. If you had the menu would show PAL and NTSC.
    Try the link above.
  4. jmack
    jmack
    you can get the info of what signal is being displayed by going into a menu on the plasma,
    hold the volume button on the plasma in while pressing the status button 3 times very fast on the remote ,
    this will bring up a menu, highlight the icc option and press enter on the remote( the square button),
    in the top right hand corner of the screen it will tell you what signel is being shown ie, 525i 525p 625i 625p etc.
    to get out press the setup button the turn the plasma off on the panell itself
    DONT MESS AROUND IN THERE BE CAREFULL
  5. NicH
    NicH
    Thanks, I guess I'll have to hack it myself then
