Pal Progressive and Scart RGB
Discussion in 'Projectors, Screens & Video Processors' started by calibos, Jun 19, 2003.
  1. calibos
    calibos
    Aug 4, 2000
    930
    Ireland
    +33
    I'm just wondering will Official Pal Progressive players (ie not modded or hacked or new firmware) output Pal Prog over RGB scart cables and would displays such as my Panny AE300 PJ even be able to accept it over RGB.....or will it be via component like NTSC Prog Scan??
  2. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    Arcam's players are "official" PAL progressive players, no hacks or mods just works out the box; there were the first "official" PAL Progressive players. Check out their website. http://www.arcam.co.uk/
    Arcam and all other PAL prog-scan players (hack, mod, flash, etc.) output PAL progressive via component (YUV) output; therefore you will need a display that accepts a PAL Progressive component signal.
    Interestingly, Arcam are the only players on the market that can output progressive RGB. This is not "official", as all "official progressive scan" is supposed to be component only. From what I understand, this is to support projectors (some of which only accept RGB and not YUV).
    StooMonster
  3. xenon
    xenon
    May 7, 2003
    65
    11
    +3
    I read in another forum that someone got the Compacks DVD5000 (the £50 one at Safeway) doing progressive RGB out of the box but I'm not sure if it's RGBS or RGsB. Just select RGB as output of choice and press the PROG button to switch between interlaced/progressive as you do with the component outs. Can anyone confirm?
