Pal Progresive .......which Plasma ?
Discussion in 'Plasma TVs Forum' started by rjrodders, May 28, 2003.
  1. rjrodders
    rjrodders
    Oct 15, 2002
    717
    46
    Heathrow
    +147
    Hi peeps ,
    Apart from the Pioneer mmx 43 / 50 which seemed to growing in
    popularity , which other plasma display are gureented to display
    a PAL progressive picture
    I am looking at the lastest Toshiba,s , Hitachi,s , Pannys and
    Poss Fujitsu .
    Can anyone .... like Joe Fernand break down what the above are
    capable of regards Pal prog and Nstc.
    Any feedback appriciated.
  2. rauer
    rauer
    Feb 17, 2001
    430
    +9
    According to what I've read here, the Panasonic 5 series does that.
  3. IanM
    IanM
    Dec 17, 2002
    160
    +5
    The 50" Fujitsu P50XHA10ES will happily display both NTSC and PAL in both interlaced and progressive modes.
    Cheers,
    Ian.
  4. rjrodders
    rjrodders
    Oct 15, 2002
    717
    46
    Heathrow
    +147
    So along with the Pioneer MXE range
    The Fujitsu and Panny 5 series can also display PAL and NSTC
    in prog and interlaced mode .......
    So what about the lastest Toshiba 42 as this is a re-badged panny can
    this also display PAL and NSTC in both modes reason being i can
    purchase one of these for £2700 inc vat as opposed to £3495 for
    the pioneer MXE 43 . Struggling to find data on the Toshiba capabilities in this area , can someone clarify.
    all replys appriciated.
  5. Joel
    Joel
    The Hitachi already has a progressive scan function in the screen, and if you feed it with a PS signal from the DVD, it will disconnect its own PS function in favour of the DVD.
    Joel
  6. gileso
    gileso
    Toshiba 42WP27 is exact copy of 5-series Panasonic, so specs are the same (I think its the domestic version, as it has no timer capability).
    It does deal with progressive PAL and NTSC signals - my DVDs play perfectly on it.
  7. ncpl
    ncpl
    Jan 21, 2003
    353
    Surrey
    I think I am right in saying that the Hitachi and Fuji ALIS panels can take a PS signal, however, they do not display it as such (at least in the same way that a non-ALIS panel does). The panel will convert it back to IS to display.
  8. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    The NEC will display PAL progressive, if you can find one.
  9. rjrodders
    rjrodders
    Oct 15, 2002
    717
    46
    Heathrow
    +147
    Great feedback Guys , but still a lot of ifs and buts ,
    Just to explain further i have just bought a Arcam pal prog DVD
    and my DVD collection nearing (100) is 90% Region 2 .
    So this is the reason for me wishing to purhase a plasma that
    Display Prog PAL. At the moment i belive the options to be
    Pioneer MXE (Def does Prog PAL/NSTC as confirmed by spec)
    Panny /Toshiba (Apparentley handles Prog Pal/nstc also)
    Hitachi ( Handles Pal Prog but converts to suit ALIS type display ?
    NEC ( Same as the Pioneer , if you can find one )
    Any others ?
    It would be great to have an alternative to the Pioneer even for
    Comparision or am i forced to go the MXE route in my search for Prog pal combatibility !!!
    Thanks for all the replies so far ...........Rj
  10. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    My personnal choice would be for a Pioneer MXE.
