pal progresive on 36pd30
Discussion in 'TVs' started by soulbrother, Jan 19, 2004.
  1. soulbrother
    soulbrother
    Can anyone who has one of these t.v's tell me if it supports pal prog aswell as ntsc.i have a pioneer 737 which is only ntsc prog output,soon to be replaced by the denon 2200 0r 2900.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    I thik it does but i dont think you will see much of an improvement with PAL PS over interlaced on a 36" CRT (you may, but i doubt it would be worth the cost of the upgrade) Just my 2 cents.
