PAL Prog Scan upgrade for Toshiba SD520
Discussion in 'Blu-ray & DVD Players & Recorders' started by BigRD, Jul 11, 2003.
  1. BigRD
    BigRD
    Jul 4, 2003
    393
    far far away
    +14
    Does anyone know if there's an upgrade to allow the Toshiba SD520 to play PAL progressive?
    This machine gets a geat write up from lots of different sources and it's only £179.95 at RS. So it would round it off nicely and match my TV perfectly. Any info would be much appreciated.
    BigRD
    Toshiba 32ZP38, Sony STRDB930, Toshiba SD230, Samsung 709, Panasonic NV-HD685, Sony GV-D800E, B&W 602s, B&W CC6, Mordaunt Short MSW20
    Work to live don't live to work
  2. Timh
    Timh
    Sep 14, 2000
    5,130
    Altair-4
    +265
    Forget it....
    I have the 510 and hassled Toshiba about a pal prog upgrade, but they cannot provide one, its not possible with the hardware on board, I believe the 520 is similer.
  3. BigRD
    BigRD
    Jul 4, 2003
    393
    far far away
    +14
    Thanks Tim,
    I'd thought about buying one but I'll not bother if that's the case:(
    I've just bought the TV so I'd like a PAL PS player to go with it. No point in just going for an NTSC only model.
    I like the idea of the KiSS DP500 with the ethernet connectivity but am not convinced the picture quality would be as good as the likes of the Toshiba (TBH I haven't seen one in operation). I suppose it's early days in its life yet and the DP550 & 600 are supposed to be launched soon.
    I assume your using the NTSC PS on your 510 so can you tell me if you noticed a considerable improvement in picture quality. I can stick to my new SD230 for a few months or so until more PAL PS models appear.
    Cheers,
  4. Timh
    Timh
    Sep 14, 2000
    5,130
    Altair-4
    +265
    Yes, i use progressive NTSC on my Panasonic AE100 lcd projector, there is a big jump in picture quality when using progressive scan but then again the de-interlacer in the AE100 is pretty poor, hence the advantage of progressive scan. On a recent test with my 510 on a Sanyo plv-30 projector, the progressive scan was only slightly better than interlaced, because the plv-30 has a superior de-interlacer than my projector.
    Yamaha have just released a pal prog player the dvd-s540 here and I believe Toshiba are releasing the sd-530 which may be progressive pal.
    Make sure your tv does progressive pal as some progressive scan tv's only do NTSC progressive.
  5. BigRD
    BigRD
    Jul 4, 2003
    393
    far far away
    +14
    Thanks again Tim,
    My TV supports PAL & NTSC PS. It's the new Toshiba 32ZP38 Picture Frame 2 :D
    I'm very interested in the new Yamaha it looks a stonker of a player but I'm in no hurry though so I'll wait and see what the new Tosh 530's like.
    Regards
