Pal prog scan player for my PTAE100??
Discussion in 'Blu-ray & DVD Players & Recorders' started by Dodgey, Dec 16, 2003.
  1. Dodgey
    Dodgey
    Hi folks, been out of the loop for a while..... I currently use my Mac (and sometimes PC to watch movies on my Panny PTAE100 PJ. I use a HTPC/MAC because I like prog scan, and I can get pixel perfect.
    I have noticed that PAL & NTSC prog scan dvd players are common and cheap now.
    Can anyone recommend a PAL/NTSC (both) prog scan player, say within £350 and are the results as impressive as using a PC?
    I'm looking at this because frankly, I'm tired of tweaking my computers and want to simply use a commercial player (and my bird can use it too).
    I've looked at an ad for a Sony NS730 which is only £149!! It says it has prog scan outputs - what does this mean - does it have a vga socket, or an extra set of component outs? (Sony's site is useless!)
    R
  2. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    Normally the usual suspect brands at that price range output prog scan via the component output.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    A HK DVD25 or marantz DV4300/4400 could be yours for that money (using YUV) for PS image!
    I reconmend the HK personally Limited edition 506 is same player in a nicer package!
  4. Dodgey
    Dodgey
    I've done some reading on the DVD 25. Am I to understand, that after running the hack CD it will play both reg 1 and 2 in Prog scan. The review here seems to imply it will only prog scan for R1 discs?
  5. Dodgey
    Dodgey
    Don't worry, done a load of searching. Seems the review here was wrong. Me off to get a 25 :)
  6. SamirP
    SamirP
    Apr 28, 2003
    1,232
    South Of The River
    +32
    the HK25 gives both Pal & NTSC prog scan out of the box;)
  7. Dodgey
    Dodgey
    just got one :)
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    What do think mate???
    Croc is after a PS DVD, do think the DVD25 performs?
  9. nwgarratt
    nwgarratt
    May 5, 2002
    26,447
    +2,873
  10. Timh
    Timh
    Sep 14, 2000
    4,835
    Altair-4
    +142
    Do you have a link for more info on the Marantz dv4400, I can't find any mention of it being progressive scan.
    cheers
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    DV4300 definatley PS i would assume 4400 its replacement to be PS as well.
  12. Dodgey
    Dodgey
    Well the DVD25 is superb. Tested it last night with NTSC & PAL progressive and it is stunning. Works perfectly, looks and sounds great :)
    I didn't look at the cheaper ones simply because I have just spent £1000's on a new speaker and sub setup and thought "why skimp on the source"
    Most pleased. Not more dicking about with htpc!
  13. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,081
    41
    Tamworth, Staffs
    +21
    Dam now I'm really tempted!:( Mrs Croc is going to eat me for breakfast:suicide: spending that kind of dosh so close to Christmas after forking out soooo much on the little Crocs:D
    Croc
  14. ant1973
    ant1973
    I asked Marantz yesterday whether the 4400 was ps. The answer was no - apparently they are saving this feature together with Faroudja for high end products. Seems like a bit of a turn around from the 4300
  15. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    Idiots! oh well never mind get a HK DVD25/2550/506 while the prices are so good then!
  16. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    Hornydragon,
    Why do yo rate the HK players so highly? Are they a cut above most other 'budget' prog scan DVD decks?
    I would like to know as in the market for a new DVD deck myself, and the HK machines look fine,but I have never seen the PQ.
    Would they suit a Panny AE300 ?
    Thanks,
    Cap:)
  17. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    I rate them so highly as they are bloody good!
    good value good machine and easy to use!
    will suit any PJ or plasma that is PS enabled!
    compared to the sub £200 machines i cant comment but when compared to much more expensive player quality is still there and half the money i friend/work associate is very big in Projectors and for component demos he uses a DVD25 which he rates higher than the Arcam DV88+ he had (a lot of people wont be happy about their £1000 unit being bettered or at least equalled by one that is a third of the price.) also running it in PAL PS is so simple you dont even notice the fact! (operation wise)
    I will say however i dont own one of these. (use one a lot though)
    But if i get a PS display then its going to take an awful lot to get me to buy anything else!
  18. Dodgey
    Dodgey
    I agree. The ease of use is a big plus. Everything works out of the box. Also, it has a great "info" screen that shows, during playback, the video mode, audio mode etc etc, Most useful. And it's black and shiny
    Also, they guy in the shop I use, who I have good reason to trust used to work for HK (not any more) and said that the HK25 is by far the best player for £300 you can get at the moment. Don't know if it is worth the extra £150 over the comparable Sony, but I have good faith in the HK brand and not so much in Sony (two mini hifis I have of Sony's packed up just out of warranty)
  19. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,081
    41
    Tamworth, Staffs
    +21
    Sounds hopeful as I've just ordered one (well the DVD2550 silver version) £250 from Home Cinema Heaven:)
    Croc
