Hi Guys, i'm currently thinking of getting a new dvd player for use with my tosh.
I would like one with PAL prog scan but just want to know if this set does it ok, as I had the Sony 730 and didnt at all like the PAL prog scan that it was outputting.
Will a more expensive dvd player such as the Myryad Z122 give me much better results ? The sony seemd to flicker a tad and after a while gave me headache.
What higher end dvd players are you using with your tosh 42wh36
Mart...
Mart...
