PAL Pro Scan?
Discussion in 'Blu-ray & DVD Players & Recorders' started by clowner, Aug 31, 2005.
  1. clowner
    clowner
    For players that state they are PAL progressive scan does this mean that if the player was modded to be a mulit region player that NTSC discs would not be displayed in pro scan?
  2. Miniholic
    Miniholic
    Apr 26, 2001
    3,046
    The Shire
    +398
    NTSC progressive scan was available on DVD players before it's PAL counterpart was ratified, so when PAL progressive was made available it was seen as quite a step forward. Most players that support PAL progressive are fine with NTSC progressive too.
    Do you have a particular player in mind?
  3. clowner
    clowner
    Was looking at the Denon 1910 but after reading an AV mag (cant remeber what) i was looking at the tosh 150 or 350 as it said the pic was as good as players costing 200+.
    Any recomendations on a good player, with component pro scan and outputs 720p (not sure is the tosh do this)
  4. Miniholic
    Miniholic
    Apr 26, 2001
    3,046
    The Shire
    +398
    The players that I know of which will upscale to 720p will only do it via a digital (HDMI/DVI) connection. I am sure there will be one somewhere that will upscale via component, but I've not come across it yet.
    I've not seen any of the latest models, so can't really make a recommendation, but a few people on here are raving about the pioneer 575 saying that it beats the newer 585, although this doesn't upscale.
    Have a look at these threads.
    http://www.avforums.com/forums/showthread.php?t=239420
    http://www.avforums.com/forums/showthread.php?t=235963
    http://www.avforums.com/forums/showthread.php?t=226761
    The samsung machines (HD950 I think) also seem to attract good reviews.
