pal or rgb
Discussion in 'Blu-ray & DVD Players & Recorders' started by den9112, May 4, 2007.
  1. den9112
    den9112
    Feb 8, 2004
    2,188
    83
    +365
    hi, i have just purchased a new digibox and a panasonic dvd recorder . i have been going through all the settings after finaly setting evrything up . in my panasonic digibox set up i have the option of pal or rgb in the picture settings on the video output option could anyone please advice on which one i should be selecting . thank you
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    You'd probably get answers to this more quickly if you post the same question in the DVD recorder section of these forums - and also include the model number of the recorder in your post.
    RGB would be preferred if your recorder accepts it (higher quality picture).
    Chris Muriel, Manchester
  3. gd2
    gd2
    RGB
