pal or ntsc
Discussion in 'Blu-ray & DVD Players & Recorders' started by Churnobyl, Mar 26, 2006.
  1. Churnobyl
    Churnobyl
    Sep 22, 2005
    219
    swansea
    +5
    i have a region2 dvd machine,if i buy discs on the web,do i choose pal or ntsc discs?
  2. mjcairney
    mjcairney
    Oct 26, 2003
    7,293
    2
    137
    Airdrie, Scotland
    +1,079
    If it's only Region 2, then you should buy PAL discs.
    Cheers,
    Martin.
  3. dgkp
    dgkp
    If you have a region 2 only player then you should by region 2 or region 0/all discs only. Region 2 discs will usually be PAL, but not always. Not all PAL discs, though, are region 2--e.g., region 4, Australia, is also PAL.
    You should look into making your player multi-region. It's the only way to go.
  4. senu
    senu
    Aug 26, 2005
    19,349
    Denham, South Bucks
    +2,811
    Yep .
    Get a multi region machine or at least one that can easily be hacked to be that way if your machine cannot be hacked to be so.
    That will ensure that the regional differences in DVDs sourced from any where will not be a problem.
    As for the NTSC/PAL issue ,most modern DVD players destined to be used this side of the atlantic will play both as some region 2 DVDs are NTSC .
