PAL or NTSC?
Discussion in 'Blu-ray & DVD Players & Recorders' started by sweat100, Nov 1, 2004.
  1. sweat100
    sweat100
    Recently got hold of a few divx movies and wanted to convert to DVD. I am currently thinking whether to use NTSC or PAL format. Which one produce better resolution? From my shallow knowledge, PAL uses 625 lines, 25fps. NTSC uses 525 lines, 30fps. If i am not wrong the more lines means more resolution right? But the fps also holds me back as NTSC has more. Since in a real film, it is only 24fps, so using 25fps also no problem right?
    Is there any clear comparison which is a better system?
    If my whole concept of this PAL and NTSC system is wrong, please enlighten me.
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,526
    Somewhere in South Yorkshire
    +5,999
    I'm not a DIVX expert by any means, but I have to guess that these have a native format of their own. What not to do, is convert, unnecessarily, the frame or line structure to something different. This always results in degradation.
