pal on plasma
Discussion in 'Plasma TVs Forum' started by keyser, Dec 21, 2002.
  1. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
    Is noone bothered by the fact that on a standard def. plasma you are loosing(or getting downscaled) up to 90 lines of resolution from a pal DVD picture?
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Yes, that's why I am going to buy a Pioneer 433MXE. Go on keyser, you know you want to:)
    Steve
  3. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
    :) Well actually the poor black levels and softer picture are what´s keeping me from buying a Pio. I think that poor black levels in my totally black room would just be untolerable.
  4. steelej
    steelej
    Keyser,
    It doesn't bother me in the slightest, PAL DVD's still look better than NTSC that run on the panel's native rate. Buying a Pio won't be any better, 'cause that has to upscale.
    John.
  5. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
    But upscaling and making full use of a signal must be better.. Anyways, that wasn´t my point.. just the fact that you are not fully using the already limited resolution of DVD bothers me, that a cheap CRT actually has more resolution would bother me. Because resolution really does matter much for PQ.. just look at the difference between HD and SD.. and you can get an overall idea of how resolution can improve the picture by the pixelplus or drc(an idea..do not include the pixelplus and drc arfitacts.)
    And HD will come in the next years, if not for TV then in the consoles first, which will be much better on HD plasmas.
  6. CarlB
    CarlB
    Jan 8, 2001
    1,351
    Cambridgeshire
    +272
    Check out the HD-DVD sticky thread in the DVD Talk section, this issue has been covered in some detail.
