Since plasmas do not suffer from 50hz blinking, will then a pal dvd look slightly better on a plasma than a ntsc dvd. The ntsc is 60hz but has lower resolution.. since the refresh rate isn´t a problem on a plasma then the higher resolution of 100lines or so from pal will make the image a little better...... or will it???
