P
potato
Id posted the same question on another forum but received no answer, so I would like to try in here to see if I have luck or not.
Here it goes:
Ive been reading about DVD player with component out for sometime now and decided to have a new player with it; but then I came across this progress and interlace, according to what I read, mostly said progressive is better; then I run into this PAL/NTSC progressive and am not able to find out which one should I get.
I have the following questions:
1. my PJ has component input (with BNCs), does it mean I can connect any player with component out into this PJ?
2. is the PAL/NTSC progress depend on the DVD played or the type or TV (or PJ in my case) used? I think my PJ is multi-system (i.e. it displays both PAL and NTSC movies) but I watch mostly R1 DVD (which is NTSC), so am I better get a player with PAL or NTSC progressive?
Thank you very much for your time.
P/s. I think this is an obvious question to most of you therefore no one bother to answer in other forum, so could you please kindly point me a direction to go for more information? Many thanks.
Here it goes:
