B
Battlehound
On my Mico Pregon Multi region player, I have an option of choosing between PAL, NTSC or "Multi", so when I play a region 1 disc I have noticed that in PAL mode it seems jerky/juddery when the camera pans across a scene. When I switch to NTSC though, there is no jerkiness at all but the lines/pixels are more visible on the screen, I prefer the picture quality on Pal mode but I have to play in NTSC mode to make sure its smooth. It has done this on both R1 discs I have, Scarface and Leon. If I choose multi it defaults to NTSC on those discs.
Is this something specific to my player being a bit of a cheap one or have others noticed this difference?? Maybe if I got another MR player this difference would not be so noticeable?
