PAL / NTSC compatibility
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by jonesyboy, Jul 27, 2003.
  1. jonesyboy
    jonesyboy
    Dear all,
    does anyone know of a camcorder that can be used with both PAL and NTSC tapes? I currently live in the UK but will be moving to Canada in the near future and would like a compatible camcorder, if there is one! I have heard that there are third party converters. Is this true and do you have any idea of the price?
    Thanks for your help!
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    There is very little difference between NTSC & PAL tapes. NTSC tapes are slightly longer as NTSC runs faster (I think its that way round :confused: ).
    The thing to be careful of is that if you want to play a PAL camcorder into an NTSC TV then you wont be able to (PAL will play NTSC, but thats no help to you :clown: ). You will only be able to play you recordings if you edit them on a PC and then convert to NTSC, or get a hardware converter but these are expensive. Analogue (for playback only) around £200, digital (playback & record) £500 up :eek: . Prices may be lower in Canada.
    Mark.
  3. jonesyboy
    jonesyboy
    Thanks for your help Mark!!!
  4. jonesyboy
    jonesyboy
    Mark,
    I've had a look around for computer software which can convert to NTSC but don't really know what to look for. Can you recommend any?
    Cheers!
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    Ok I had a look for PAL>NTSC conversion programmes and found this on the Computer Video forum:
    else you could try Canopus Dv file Format Converter for £234
    Or
    Sonic Foundry Vegus Video $400 (US download)
    Hope this helps,
    Mark.
  6. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    Sorry forgot to say, I can not actually recommend any of these as I have not used any of them and am just offering info on what I found.
    Mark.
  7. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    Canopus Procoder is a good piece of software . I use it to MPEG encode my video for DVD authoring. It is an excellent multi format encoder & does PAL/NTSC (& vice versa) conversion.
    Not cheap mind you, but you are getting arguably the best software MPEG encoder.
    (I just happen to use Vegas Video for editing as well - great NLE ;)
