PAL/NTSC brightness difference
Discussion in 'Blu-ray & DVD Players & Recorders' started by dude, Jan 20, 2003.
  1. dude
    dude
    Hi, I have a Harmon Kardon DVD25 and have noticed that when i change between PAL and NTSC that there is a difference in the brightness level. Is this normal or is it my player??? If it is normal how is then it possible to get the the correct setting (with a test DVD).
