PAL Gamecube Digital Out
Discussion in 'General Video Gaming Chat' started by Rich1978, Jun 18, 2002.
  1. Rich1978
    Rich1978
    Apr 28, 2002
    93
    9
    Bedfordshire, UK
    Maybe the answer is the instruction booklet - but that's at home and I'm not at the moment.
    I've just got a PAL Gamecube and am aware that the S-Video output on this model has been disabled, but does this mean that the Digital Out socket is also useless?
    If not, what can the Digital Video out socket be connected to? I'm looking for a way to increase the picture quality.
    The picture will be feed into my projector that can accept Data, Component and RGB through a VGA lead.
    Any suggestions appreciated.
    Rich
  2. andyk
    andyk
    Dec 31, 2001
    769
    46
    North Yorkshire
    +166
    you can use the digital out port to output component video. There are a couple of threads about it already.
    Your other option would be to get an RGB lead and use that (that's what I have done and it is v. good, but then I don't have component in on my TV, so I didn't have much choice)
  3. NeoBlade
    NeoBlade
    Yeah, RGB Scart is the way to go alright, unless you have a plasma TV then pump for the component leads. Theres also a DVI (Digital Video Interface) cable that goes into the digital out socket... But you can only get these direct from Japan. Plus its also rather useful for us NTSC Gamecube owners since you can modify these and have an RGB display...
  4. Rich1978
    Rich1978
    Apr 28, 2002
    93
    9
    Bedfordshire, UK
    I think I'm going to try the component option. There seems to be something from www.lik-sang.com that fits the bill.
    Thanks for your help guys.
  5. John Jennings
    John Jennings
    Aug 7, 2001
    282
    Uppsala, Sweden
    +5
    Be sure that it works on PAL machines. The video cables for the Analogue AV-out aren't compatible between NTSC/PAL. Also, FYI, the PAL gamecube doesn't do progressive output, only interlaced.
  6. fuzzybee
    fuzzybee
    Apr 27, 2002
    1,498
    Chesterfield town of the crooked (Spire)
    +72
    The official japanese component cable does work with a pal machine as I am using one which I bought from lik-sang.
    The cable is video only connected into the digital out on the GC so you will also need the L+R audio of the composite scart pluged into the AV out.
    As John Jennings correctly says the pal GC only does interlaced component but it is very good(at least we agree on something John)
  7. John Jennings
    John Jennings
    Aug 7, 2001
    282
    Uppsala, Sweden
    +5
    :D
  8. Oli
    Oli
    Oct 22, 2002
    291
    Nottingham
    +6
    Sorry, bumping a very old thread here!
    Basically, i want to take the output from my gamecube into my TFT monitor, i know this has been asked a million times before but the only options seem to be to use a crap VGA converter box thing..
    Is it not possible to get an adapter for:
    http://www.lik-sang.com/info.php?category=76&products_id=777&
    I heard the japanese DV cables are different, but surely theres some way to go from that to DVI without much signal loss?
  9. t-force
    t-force
    May 2, 2001
    1,864
    Southampton, UK
    +151
    IIRC, that cable terminates with the Japanese D-input connection, and is pretty much incompatible with anything in the US or European markets. Don't know what you could do really to go into a TFT, unless it supported component input.
  10. Markie Boy
    Markie Boy
    Dec 13, 2002
    1,260
    63
    Perth, Western Australia (Originally Ireland)
    +226
    Buy the component cable, buy a Freeloader disc and import NTSC games. That way you'll get Progressive Scan (480p).
  11. Oli
    Oli
    Oct 22, 2002
    291
    Nottingham
    +6
    Then i'd need a scan converter for component -> DVI, then i wouldnt be able to play my current games i presume?
  12. fdxd
    fdxd
    Yup. Besides its better than RGB without progressive scan anyway. More reason to buy.
