PAL disk NTSC Progressive out
Discussion in 'Blu-ray & DVD Players & Recorders' started by Stimpy, Nov 21, 2003.
  1. Stimpy
    Stimpy
    Have just got my Pioneer 565A and was wondering.
    What is the effect of playing PAL disks using NTSC progressive out.
    I.e. will there be bigger libsync issues, will the picture be squashed or stretched???
    Havn't had time to set it up yet but any advise would be welcome.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I don't think it will work but you may try it out. Let us know how it went.
  3. Stimpy
    Stimpy
    The manual with the player says that PAL disks can be played with NTSC progressive out.
    Confused me as well
  4. Badger
    Badger
    Jan 21, 2002
    259
    I'd imagine it throws away the extra PAL lines and repeats frames to get from 576 lines @50Hz to 480 Lines @60Hz
    Might look OK but might look nasty and jerky
    Phil
  5. S H A D O
    S H A D O
    Mar 16, 2001
    10,438
    United Kingdom
    +1,820
    My Toshiba SD900 can do this. It converts PAL to NTSC and then outputs this progressively. Unfortunately it looks crap and has nasty combing effects all over the image. :( Other players may make a better job of it though.
  6. Cadire
    Cadire
    Oct 18, 2003
    146
    Sussex
    +10
    The 565A will play them in progressive mode, but you'll notice dropped frames.
  7. Stimpy
    Stimpy
    Oh well. No progressive mode for me
  8. Badger
    Badger
    Jan 21, 2002
    259
    surely you'll get repeated frames rather than dropped ones ?
    You have 25 PAL frames to fit into 30 NTSC refreshes - so the easiest thing would be to duplicate a frame every 5 refreshes
    It may well look nasty though, try it and see
    Phil
    [edit] I have of course assumed it will create each of the 25 PAL frames first and the convert them to NTSC output rather than some other way of doing it
  9. Cadire
    Cadire
    Oct 18, 2003
    146
    Sussex
    +10
    It could well be duplicated frames (I'd not thought of that), but the picture gets 'jittery', especially noticeable during fast movement. Tis jerkiness looks like dropped frames, but could well be due to frames being repeated now I think of it.
