pal carrier change panasonic tx28sk1c
Discussion in 'General TV Discussions Forum' started by CABBAGEMAN, Feb 12, 2005.
Tags:
  1. CABBAGEMAN
    CABBAGEMAN
    Can anyone say if a change to the audio carrier is possible on a panasonic TX28sk1C which is currently PAL-G and needs to be PAL-I for the UK.
    I know I can use a seperate tuner via the scart but I'd prefer the extra option of using the built in tuner.
    If you don't know the model , is it possible in principle on panasonics ?
