Pal and NTSC progressive scan
Discussion in 'Blu-ray & DVD Players & Recorders' started by Fordy, Jul 4, 2005.
  1. Fordy
    Fordy
    Jul 9, 2003
    1,537
    41
    Liverpool
    +24
    Which player supports Pal and NTSC progressive scan?
    I was hoping for a Toshiba but I cant find one that does it.
    David
  2. msg
    msg
    May 20, 2005
    422
    Darlington
    +14
    If you DON'T require HDMI connection, but will be using component, then the following Panasonics should meet your needs S29 and S49.
    If HDMI is required, then you'll want the Pansonic S97 or Samsung 745, 850, 945 or 950 (latter model not yet available)
    Dave
  3. domtheone
    domtheone
    Nov 23, 2004
    13,675
    Nottingham
    +2,393
    I'm pretty sure that there are a number of Tosh models that support PS with both PAL and NTSC...
    Try the 340E for starters.
  4. Fordy
    Fordy
    Jul 9, 2003
    1,537
    41
    Liverpool
    +24
    Its just that its not clear on the toshiba site that any of them support NTSC PS.
    Or anywhere for that matter.
  5. Fordy
    Fordy
    Jul 9, 2003
    1,537
    41
    Liverpool
    +24
    Just checked again, the Toshiba site doesnt say NTSC progressive, should I just presume that they support this function?
  6. smithgt
    smithgt
    Oct 16, 2004
    9
    I have just purchased an SP5000 1280x720 Projector.
    My old projector was connected via Composite Video from Sky, DVD & Tivo.
    As this new PJ supports component in I was thinking of getting a Panasonic S49 as that offers component out and Optical to my AMP. I don't need to replace my DVD player as such, but I want the best signal I can get to really show off the PJ.
    Should I take this route, or will SVHS be up to the job?
  7. domtheone
    domtheone
    Nov 23, 2004
    13,675
    Nottingham
    +2,393
    Fordy.
    Have a look at:
    http://www.homecinemachoice.com/
    Search for Tosiba DVD Reviews. Some of the reviews (that one I looked at was the 340) state support for PAL/NTSC PS.
  8. Fordy
    Fordy
    Jul 9, 2003
    1,537
    41
    Liverpool
    +24
    thats settled then
