pal 60hz query
Discussion in 'Xbox Forums' started by p5yco, Dec 30, 2006.
  1. p5yco
    p5yco
    May 14, 2005
    220
    norwich
    have i made a mistake!? i bought an xbox 360 a few days ago and all is working fine. however some of the games now display 60hz on the covers, does this mean they wont play at all if my tv doesnt do 60hz!? is there a way around it if this is the case? please help
  2. Incrediboy
    Incrediboy
    Apr 13, 2005
    822
    Singapore
    +83
    I would be surprised if your tv didn't support 60hz. It just means your 360 has to output an extra 10frames a second.
    If you're really uncertain you can always look up the model number of your tv and see from the brand website if it is 60hz compatible. As for a way around it, I don't think there is. Not 100% sure on that last statement of mine though
