Pal 60?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Ono, Apr 1, 2001.
  1. Ono
    Ono
    Oct 18, 2000
    1,642
    London
    +221
    Some of the players are modified for PAL 60. What is it and do I need it?
  2. Arthur.S
    Arthur.S
    Normal PAL is 50hz. NTSC is 60hz. PAL60 retains the 60hz of NTSC , so should work with a TV that is not fully NTSC compatible. Notice I said 'should'! See my post 'This LG hack works, for more info.
    www.baldyplex.com
