Pal 60?
Discussion in 'Nintendo Forums' started by Bigpants2k, Jan 6, 2004.
  1. Bigpants2k
    Bigpants2k
    Jan 8, 2003
    209
    Bracknell
    I just got myself a new TV, a Sony 32FX68.
    I just wanted to know should I change my X Box to PAL 60? (what is this).
    If any of you guys have this TV, which Scart do you plug your X Box into?
  2. CMcK
    CMcK
    Mar 18, 2003
    407
    Scotland
    +29
    Plug your Xbox scart into the socket marked AV1 or RGB. Usually on the right hand side if your facing the back of the TV.
    Try the PAL60 option on your Xbox in theory you will get a smoother update. Halo is best at normal PAL 50 though.
  3. Tesla
    Tesla
    Dec 9, 2003
    940
    Bristol, UK
    +32
    Why is this?
    \\Chris
  4. -Spike-
    -Spike-
    May 17, 2001
    1,585
    E.Sussex
    +287
    Tesla,
    Halo has a slight stuttering effect when PAL60 is used.
    PAL50 and it is fine.
  5. Bigpants2k
    Bigpants2k
    Jan 8, 2003
    209
    Bracknell
    Thanks will try tonight.
  6. andy572
    andy572
    Dec 4, 2002
    362
    Oop North
    The story goes (and it may well be just that! :D ) that Halo was coded for PAL 50, with no provision for 60 Hz. Assuming that is true, you're just seeing the effect (for simplicity, we'll ignore possible slowdown) of 'missing frames'. The console is playing 'catch up', if you like (drawing frames twice?).
    Okay, I've just had a search for some info. There's a little more than necessary (referring to playing between PAL and NTSC version of the game, for instance); but as it's from Bungie, it must be good :)
    So, er, there we go! :laugh:
