PAL 60 - erm, how?
Discussion in 'Xbox Forums' started by oisky, Mar 11, 2006.
  1. oisky
    oisky
    Apr 11, 2005
    32
    Downloaded the outfit demo but it only works in PAL 60. I'm connected component 720P and when I go to the system blade I can't select PAL 60. How the hell do you change from PAL 50?
  2. Thxfan
    Thxfan
    Sep 13, 2005
    107
    York
    +7
    I think it depends on the capability of your display device. What make of Tv are you using?
  3. oisky
    oisky
    Apr 11, 2005
    32
    panasonic 42 HD 500 (can't remember the exact number)
  4. movaado
    movaado
    Dec 16, 2005
    514
    46
    Sittingbourne, Kent
    +220
  5. oisky
    oisky
    Apr 11, 2005
    32
    cheers
