pal 60 0n xbox
Discussion in 'Xbox Forums' started by leedsfireman, Dec 29, 2002.
  1. leedsfireman
    leedsfireman
    Mar 21, 2002
    1,232
    38
    +3
    hi, can any body tell me what this setting changes in set up menue, i use a panny plasma if thats a help.
    andy.
  2. Dom H
    Dom H
    runs games at 60Hz instead of 50, games are smoother but you lose some resolution.
    Once you get used to 60 you wont wnat to use 50 again
  3. Mr THX
    Mr THX
    Nov 26, 2002
    1,309
    Barnsley
    +32
    Read some earlier threads about some games running jerky when using diffrent settings ??
    Does it make any diffrence if your using a 50 hz or 100 hz TV.
  4. Dom H
    Dom H
    Halo is the only game I know of that seems to run better in 50Hz mode.
    I presume 100Hz sets also do 60Hz.
  5. museumsteve
    museumsteve
    Jan 28, 2001
    7,914
    4
    Nth Hampshire
    +1,067
    Max Payne is another that struggles in PAL60..
  6. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    If they do a proper port, as in the case of Halo and Max Payne, turning to 60Hz will screw up. 60hz also does strange things to some 100hz tvs.
    You should use PAL60 when its clear there are borders at the screen bottom.
    Neil.
  7. Sunday Ironfoot
    Sunday Ironfoot
    Does anyone knoe why some games actually seem to run slower in 60Hz mode?
  8. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    Because they have been properly ported to 50hz and the different clock causes the games internal timing to screw up.
    Neil.
  9. Sunday Ironfoot
    Sunday Ironfoot
    Cool, any links that explain this in more detail, thanks!
