Painting TV
Discussion in 'Home Cinema Building DIY' started by lostprophet, Oct 6, 2004.
  1. lostprophet
    lostprophet
    May 11, 2003
    288
    Not the light side....
    +12
    Hi Guys, odd question I know but I was wondering what your opinions would be for me to paint my TV.
    Its got a couple of scuffs round the frame at the front surrounding the screen that really bug me. Basically I figured it would be easy enough to mask off the screen etc and respray the whole front frame. Just wondered if there was any advice anyone has to offer such as types of paint, whether I should sand it down or if its just a bad idea??!
    Oh and my TV is silver by the way
  2. andhoey
    andhoey
    Jul 23, 2004
    80
    9
    try hammerite smooth silver you get it in a spray tin, i sprayed my video and sky digi box with it. :D
