Painting over a mural
PaulaB
I put 4 coats of paint over a mural in my bedroom. It has managed to come through this. I have been told that dilute pva glue on the wall will seal it in so I can paint over it again, is this true and if so how much water to pva glue to use?
Peter Parker
It should tell you on the can it comes in. I think 6 water to 1 pva is the ratio often used to seal things such as porous ceilings and flaky walls etc.
Gary.
galthop
Try a coat of white undercoat and then paint over that. It worked for me to cover some very stubborn biro.
RichardH
...Or you can get that paint to put over old damp stains - might be worth a go if the PVA sleaing coat doesn't work. By the time you've got it sorted, you may have a smaller room......
Prey + Bullet Train reviews, Heat 4K + Event Horizon 4K and all the latest movies and TV news
