Painting garage floor
Discussion in 'General Chat' started by Sandman, Nov 7, 2017.
Tags:
  1. Sandman
    Sandman
    Nov 28, 2002
    3,774
    Glasgow
    +1,682
    As I didn't win the £20k home cinema competition and wont be converting my garage for a couple of years I am going to paint the concrete floor to make the place a little less dusty.
    I am planning on using this stuff-
    https://www.amazon.co.uk/Ronseal-Diamond-Hard-Steel-Blue/dp/B00OYSN5Z6
    Have I left it too late in the year to paint as the temperature has dropped considerately over the last week or so or should it be ok? I could even hang an electric patio heater from the ceiling to keep the temps up while the paint is drying.
    Has anybody used this type of paint and is it hard wearing? I wont be putting my car in the garage but I do play table tennis in there and there will be a running machine and cross trainer going in soon.
    Also should I use a brush or a roller for the best finish and what preparation is required? It is a new build house so the concrete floor is less than a year old (and very dusty).
  2. BB3Lions
    BB3Lions
    Apr 24, 2009
    14,696
    3
    +6,570
  3. aerodynamic18
    aerodynamic18
    Oct 26, 2008
    2,002
    116
    N.Ireland
    +1,378
    Make sure you seal it first. Makes a better job
  4. Sandman
    Sandman
    Nov 28, 2002
    3,774
    Glasgow
    +1,682
  5. mjn
    mjn
    May 24, 2001
    24,382
    Herts, England
    +13,142
    Latex paint?
  6. aerodynamic18
    aerodynamic18
    Oct 26, 2008
    2,002
    116
    N.Ireland
    +1,378
    when you seal it, make sure you have ventilation. Its strong stuff lol. I had the internal door closed that leads into the house and the next morning when i came down the smell on the ground floor was epic lol
  7. jassco
    jassco
    Feb 10, 2009
    6,160
    +3,240
    Seal / paint just over half, then when dried do the other half?
  8. John
    John
    Dec 13, 2002
    11,646
    +3,322
  9. MartinMiller
    MartinMiller
    Oct 12, 2007
    2,090
    116
    Hamilton, South Lanarkshire
    +663
    This ^
  10. aerodynamic18
    aerodynamic18
    Oct 26, 2008
    2,002
    116
    N.Ireland
    +1,378
    Tbh next time I have this to do I’ll get the garage tiles fitted instead
  11. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,440
    Have you considered a rubber or PVC flooring solution instead?
    something like this:
    Buy Checker Plate Garage Floor Tiles - Diamex LOK | Polymax UK
    I have used something similar in my garage and it still looks perfect and it has been down for over 8 years now. It costs a more than painting I think but it is a do once solution.
  12. mikes48
    mikes48
    May 11, 2007
    1,460
    116
    Preston, Lancs
    +1,556
    Latex, you say...
    Hmm, is this a clue about another thread??? :eek:;)
  13. mjn
    mjn
    May 24, 2001
    24,382
    Herts, England
    +13,142
    Everybody likes a bit of latex, don't they?
  14. swiftpete
    swiftpete
    Sep 30, 2006
    5,185
    Notts
    +1,294
    Forget that, convert it instead.
  15. PsyVision
    PsyVision
    Dec 6, 2008
    2,176
    116
    Bath
    +1,980
    We have an exterior garage building that isn't too well sealed on the floor (bit damp over winter). It's not a flat floor so tiling it is no good.
    What is a decent paint on/liquid sealant product to use before painting?
  16. Tempest
    Tempest
    Jan 11, 2002
    8,654
    Horley, Surrey
    +4,354
  17. Sandman
    Sandman
    Nov 28, 2002
    3,774
    Glasgow
    +1,682
    Well we got new kitchen flooring today so I asked the fitters to take care removing the old vinyl flooring and I spent a couple of hours this afternoon fitting it in the garage. It looks great and perfect for my needs.
  18. IRobot
    IRobot
    Jun 28, 2006
    1,891
    116
    Leamington Spa
    +1,065
    I kind of did the same when my garage floor started breaking and turning to dust. Bought the cheapest roll of vinyl from the local flooring shop and layed it out myself. That was about 5+ years ago. I park the car in the garage every day and it's held up OK but some of the edges are starting to curl up a bit.
