Painting a PS2 and GC silver??
Discussion in 'Playstation Forums' started by calibos, May 7, 2003.
  1. calibos
    calibos
    Aug 4, 2000
    931
    Ireland
    +33
    Just wondering if anyone has painted their consoles??
    I'd love to paint my PS2 and Gamecube silver to match the rest of my gear and was wondering if anyone else has done this. Surely its been done by someone seeing how popular PC case modding is? I've done a bit of googling on the subject and haven't turned up anything. So has anyone done, this and can give me tips or has anyone got any links to sites were the procedure might be explained??
  2. NeoBlade
    NeoBlade
    I'm sure some peeps out there have done it. I've seen quite a few modded Xbox cases and PC ones and (if done right) it can look good. If you do choose to spray it though make sure you prime everything. Take the case off before starting anything of course!
    Clean the surface so its free from dust, grease etc, prime it so the paint/spray will stick and just go from there... Basic I know but thats all I currently know ^_^;;
    Best to keep on searching for more professional tips.
  3. phenom2003
    phenom2003
    http://www.magickcupboard.com/Skankhair/
    Look in the tutorials and links section, and look at the general shell modding part. This should give all the advice you need to change your Gamecubes apperance
    Richard:smashin:
  4. calibos
    calibos
    Aug 4, 2000
    931
    Ireland
    +33
    Cheers Richard
  5. bash
    bash
    Nov 10, 2002
    2,945
    London
    +611
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Local computer fairs ioften have people selling or recasing console so might be worth a look search google for "computer fairs uk" you can often get this done for £25-40 not sure about GC though been a while since i have been
  7. calibos
    calibos
    Aug 4, 2000
    931
    Ireland
    +33
    Cheers Bash!
    That sounds like a much easier and better idea. Have you bought these? I wonder how easy they are to apply and what the end result is like. Are they a reliable company I wonder??
  8. phenom2003
    phenom2003
    These are very easy to apply, but take your time with them (have one on the XBox) the results though can vary from alright to great. Never heard of that company but the prices for the skins look a bit over the top
    Richard
  9. bash
    bash
    Nov 10, 2002
    2,945
    London
    +611
    Buy'em from ebay.
