Pain in the neck!!
Discussion in 'Projectors, Screens & Video Processors' started by Les E, Dec 20, 2004.
  1. Les E
    Les E
    Oct 5, 2004
    963
    St. Helens
    +18
    My room will be around 11ft x 8ft and around 8ft in height.
    With this in mind, and the fact I trying to pre-plan a 69" (diagonal) screen so I can position the front mid speaker at a suitable height (prior to plastering), what would be the best guide to fix the height of the screen?
    I don't want it too high that I get a kink in the neck but I need the front speaker at reasonable height as it's going under the screen.
    By the way, it will be a fixed 16:9 screen.
    Any ideas anyone? :cool:
  2. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +115
    You could mount the screen low and speakers about it
  3. smerkderk
    smerkderk
    Oct 15, 2004
    44
    Berko
    Les,
    Would suggest sitting ( at roughly the correct level) and just looking at the wall, see where your natural eye line is drawn to, then (need to check this out) but i would say that would be a good place to have the middle of the screen? however i think there is a post that suggests eyeline being 2/3 up the screen? I have my speakers above the screen and sound is ok.
  4. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    I believe I've read elsewhere that the rough guide is to have your eyeline 1/3 up the screen. I used to have an article on this somewhere suggesting acceptable vertical viewing angles, but I can't find it. Sorry :blush:
  5. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,151
    UK.
    +2,670
  6. saxo
    saxo
    Not much... We are talking how high should the screen be, not how far. But thanks.
  7. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,151
    UK.
    +2,670
    If you'd actualy bothered to look at the page I linked to, you'd have found this:
    Click here for information on vertical viewing angles, or "How high can I put my screen?"
    Nice 1st post. You'll go far.
    Gary.
  8. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    I had to put my screen higher than ideal, in fact my eyeline (whilst sitting) is in only just above the bottom edge of the screen. I haven't had a pain in the neck yet... not from the screen anyway...PJ ;)
    PS someone suggested putting telephone directories under the settee... which I thought was a novel idea, havent resorted to that... yet! :)
