Paging Ian J - 2 LFE Sub input from 1 LFE Amp output.
Discussion in 'Subwoofers' started by CJROSS, Mar 29, 2005.
  1. CJROSS
    CJROSS
    Nov 16, 2000
    5,102
    +343
    Ian Im sure Ive read before that if you have a L&R LFE sub inputs on your amp and one single LFE output from an AV amp, do you simply run into the Left input ? Or is it right – does it matter.
    TIA dude.
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    I'm not Ian but most people use the left input although it doesn't matter which you use in reality. I think it harks back to the introduction of stereo sources where if you only have a mono configuration you should use the left channel as it was guaranteed to have all of the dialogue information. :)
  3. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    CJ - I don't think that there is a standard as some subs have indentical L&R inputs but others have the second input -10db down on the other one so it depends on what type of sub you have.
  4. CJROSS
    CJROSS
    Nov 16, 2000
    5,102
    +343
    Cheers Dudes, thanks for clearing that up, I knew the left channel was mentioned before thanks for clearing that up.
