'Padding' on PVR EPG timers
Discussion in 'Digital TV & Video Players & Recorders' started by icarusi, Jan 5, 2007.
Tags:
  1. icarusi
    icarusi
    Jan 2, 2007
    96
    Do all PVR EPG timers normally have a 'padding' option? If not which PVRs do and which don't? Also which are double ended and which single ended?
  2. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    I think they can all pad somehow; the real question is which ones have an auto padding feature so you dont have to add it each time.
    marc's excellent comparison chart should help; see the scheduling section; I think.
    http://www.pvrjunction.co.uk/compare/
    Nb some browsers have problems with the chart; I get R for tick/yes and T for cross/no. :confused: but you can soon work it out.
    Richard
    Edit just noticed marc has sorted the browser problem; there is a button top right if you dont get the ticks and crosses
  3. bradavon78
    bradavon78
    May 31, 2004
    3,202
    South West, England
    +133
    What is double and single ended?
  4. captain747480
    captain747480
    Feb 20, 2005
    +11
    Double ended - Padding at both ends of a recording
    Single ended - Padding at only 1 end
