Packard Bell DVD-DivX 350 Hand Set Hack?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by nohoper, Jan 16, 2005.
  1. nohoper
    nohoper
    Just brought the Packard Bell DVD-DivX 350 Progressive Scan DVD Player from PCWorld. Just trying to do some research on it and of course see if there is a hand set hack for it out there?
    Cannot see anything listed or not in the "Unhackable List" Forum, so just posting this out for some input if there is any.
    Some Player Specs are as follows:
    £60 from PCWorld
    Video Support: DivX Certified, All Usual DVD Formats/Progressive Scan
    Audio: Built in MP3 Decoder/Dolby Digital/dts Digital Out
    Video Output: Component Out/S-Video/Composite
    Sound Output: Optical Out/Coaxial Out/Dolby 5.1 Support
    "Progressive Scan On + Disney Pixars Monsters Inc + 42" Plasma through Component Connection has restored my faith in the possibility of quality video output on the plasma screen."
  2. elderwin
    elderwin
    Just wondered, was thinking of picking one of these up tomorrow. Had a question for you though. Can you wack a load of divx files, like TV Ep rips onto a dvd and just play them "off the bat" like that. I know the KISS players will do it but not sure on this one. I would ask at PC World but can't be bothered with the blank informationless stare from the staff
    Cheers in Advance
  3. nohoper
    nohoper
    Hey Elderwin,
    Unfortunately, I came home the following day from work, and "now my evidence is not conclusive", I think my daughter had a play at loading a DVD. When I got home the display said "Open" and the tray was not open. I think my darling daughter "shoved" a disc in and it got jammed.
    Had to take it back before my trials began.
  4. elderwin
    elderwin
    hehe, no problem. As we speak I am on the phone to packard bell trying to findo out the answer... 5 minutes in hold while they check and counting.... Well after 10 minuntes the answer is that the Packard Bell "Mid Office" don't know, and kinda said suck it and see :)
    guess I will just get the local store to try it :D
  5. elderwin
    elderwin
    last note on this as it isnt really a hack. Tried one out today with a data dvd with 12 TV divx avi rips, and the file frontend worked fine and played all the eps.
  6. alpha10
    alpha10
    Jan 22, 2002
    3,197
    Essex
    +192
    I'm after a hack for this on as well, any news????
  7. mh123
    mh123
    Apr 2, 2005
    686
    Offshore UK
    +66
    Switch on from cold. Open drawer and leave open. Press the following keys:
    7 5 1 8 0 waiting inbetween each number for the little 'hand' symbol top left to disappear. 'All Regions' should be displayed.
    Needs rekeying if you disconnect power, so write it down somewhere!!
    :thumbsup:
  8. alpha10
    alpha10
    Jan 22, 2002
    3,197
    Essex
    +192
    Hi mh123,
    I haven't tried that yet, as I was told that you had to do everytime you put a disc in?
    Do you know if it's everytime you power down the front switch, or do you have to actually turn off the mains to loose it?
    Mark.
  9. Nickie
    Nickie
    Aug 6, 2005
    Have you had a chance to try this yet? Or has anyone else tried this hack? I'm thinking of buying one (they have some on eBay for like £40) but don't want to if I can't make it multi-region.
    Thanks!
  10. mh123
    mh123
    Apr 2, 2005
    686
    Offshore UK
    +66
    Hack works a treat. So far not had to re-key it; have played several discs R1/R2/R0 without any problems.
    I'm now 99% sure you only need to re-key the code after a complete power-off rather than standby.
  11. alpha10
    alpha10
    Jan 22, 2002
    3,197
    Essex
    +192
    If you turn the power off on the front button it's gone, I find this really annoying with the kids.........
    So if anyones finds a permanent hack I'd be really pleased, cos it is a really good little player other wise......
  12. mh123
    mh123
    Apr 2, 2005
    686
    Offshore UK
    +66
    Still it's only 5 numbers... a sticker on the back of the remote is all that's needed until you can remember it! I'm sure most people have a majority of R2/R0 discs anyway with just a smattering of R1/3/4/5/6.
    Great player for the money. Progressive Scan, component out and a full set of 5.1 outputs is definitely a bonus.
  13. alpha10
    alpha10
    Jan 22, 2002
    3,197
    Essex
    +192
    "Still it's only 5 numbers... "
    Is fine for us, but unfortunatly I bought this for my 2 and 4 year olds and they have a few R1s, just makes a good little player a bit of a pain.....
