Packard Bell 5.1 Dolby digital decoder
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by RichardG6PAJ, Apr 13, 2005.
  1. RichardG6PAJ
    RichardG6PAJ
  2. skaramanga
    skaramanga
    I have just bought one of these too. Seems to work well, even though it runs quite hot when in use. There is also a slight hum from my speakers too, not sure why that is, I use a coaxial input from my computer.
    Can't find info on this decoder anywhere, there wasn't even documentation with it, or anything on Packard Bell website.
  3. Pulsar
    Pulsar
    Jan 19, 2003
    2,921
    West Midlands - Stourbridge
    +292
    Hi.
    Can you tell me if this unit acts as a pre-amp for analogue inputs?
    Rob
  4. meansizzler
    meansizzler
    May 11, 2005
    7,582
    104
    London
    +266
    You need an amplifier to work with this, it is just a decoder similar to the Videologic Digitheatre Decoder, it have 6 phono outputs which you must connect to your amp or a 5.1 speaker kit....
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    "A high quality Packard Bell product..."
    That's a bit of a misnomer, isn't it ? :rotfl:
  6. Pulsar
    Pulsar
    Jan 19, 2003
    2,921
    +292
    Hi, thanks for your reply, but I think you misunderstood my question. Does this product handle volume control so it can be connected directly to a power amplifier, or not?
    Rob
  7. skaramanga
    skaramanga
    Well you can control the volume with it, if that helps.
  8. Pulsar
    Pulsar
    Jan 19, 2003
    2,921
    +292
    Thanks skaramanga, that is what I wanted to know.
    Rob
  9. Madders
    Madders
    Jan 30, 2002
    2,307
    London
    +49
    Hi Rob,
    Yep, you can use this as a preamp (I'm using it to decode my Sky at the moment) but it has a CD input and Aux input as well as coaxial and Toslink optical inputs. It also has a bypass option - not bad for £20!!
    Steve
