Package or Separates
Discussion in 'Home Cinema Speakers' started by brookesboy, Jul 29, 2005.
  1. brookesboy
    brookesboy
    Jun 6, 2005
    44
    I've just invested in my first AV and am now in the process of putting together a speaker system. I am in two minds whether to just add some rears, a centre or instead get a package. Is there a great deal of difference in terms of sound quality?
    What does anyone think would be a good compromise, and if I were to go for a package, would I be able to integrate it with my current stereo speakers?
    I have a fairly small budget - £150.00, so any advice around possible set ups would be really great.
    Thanks guys.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    The rears aren't so much of a problem but if you buy a centre speakers that sounds different to your stereo speakers, all voices and other sounds will change tone as they pan across the screen which can be a little disconcerting to some people but others couldn't care less. That's why it is recommended that the front three speakers are tonally matched.
