Pacific DVD-900 and DVD-1002 handset hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by RTpaff, Dec 28, 2004.
  1. RTpaff
    RTpaff
    Anyone looking for a hack for the Pacific DVD-900 player.
    I found on another site that it is the same as the 1002
    1 Press open/close
    2 press clear
    3 press 1 3 6 9
    4 press 1 2 3 ect for wanted region or "0" for multi region
    5 press open/close
    It will seem as if it is not working but you will see the red light flashing when you are pressing the code. It does work !!!
  2. spacemonkey9
    spacemonkey9
    I used to have a 1002 whuch i cracked from another site this one is only for my 2 daughters room. I have yet to try it, but I am sure it will work, well i at least pray it will as I am sick of watching Chicken Little in 7.1 surround.
    many thanks in advance you have saved my sanity
  3. gerbran
    gerbran
    Had to try a couple of times, but this works and lets me watch my DVDs I bought when I worked in the US!
