Quantcast
Pacific 1002w problem
S
stubetts
Just bought the Pacific 1002W from Asda after it got very good reviews, and I am not very impressed with the picture. There is a faint white "banding" moving across the screen from left to right all the time(when playing a DVD), and it is especially noticable on a dark background.
Anybody else had this problem, or have I got a faulty unit.
S
shawshankkid
hi mate , i had same prob,easy 1 to fix ...select a station that isn't tuned in so its snowy.then switch your pacific on.pefect pic ! .if you switch it on with a normal station on the tv , it picks the picture up from behind and interferes with current picture.cheers .chris.
