Pace V2 problem
mnsfldpaul
Established Member
Hi, I have a strange problem with my Pace V2. When I connect the SKY box to the tv I get no RGB only composite, however when it is connected through my dvd recorder it works in RGB ( You can see a real difference in the Picture quality) But the only way I can get a RGB picture is to have the DVD Recorder tuned on. Once the DVD Recorder is turned off it goes back to composite I am using the same scart lead and also have tried others, and it's connected from the TV out on the SKY Box and into AV1 on the TV.
Anyone any ideas ?
Paul
Mep
could it be that you're not using an RGB scart lead....the DVD could upconvert composite?
Mep
assuming they are all wired, but you may have a lose connection?...be worth trying an alternative if you have a spare laying around
mnsfldpaul
Established Member
I've tried various different scart leads but no different. I am tearing my hair out with this, just can't work out why I get RBG through dvd but not through dvd direct. It's a sony TV and you get the AV1 symbol with 3 dots indicating RGB when DVD is on, but as soon as the dvd is off or it's connected to the tv direct it only show's AV1 without the dots. And there is a drop in the PQ.
Mep
sorry to ask the obvious, but you have set sky to output RGB in picture settings?.....otherwise I'm as baffled as you.
⭐ Philips OLED908 TV & Musical Fidelity A1 amp reviews + a look at two home cinema speaker packages
Back
