Pace Twin
Discussion in 'Satellite TV, Sky TV & FreeSat' started by andyMallion, Dec 30, 2004.
  1. andyMallion
    andyMallion
    I have a Pace Twin PVR 2 questions
    1. Why does it not receive all channels?
    2. It has a card slot, will it accept topuptv?
    many thanks
    Andy
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,317
    Somewhere in South Yorkshire
    +5,669
    1: Which ones (other than TUTV) is it missing?
    2: No. And there are no plans to make it so.
  3. andyMallion
    andyMallion
    The channels missing are bbc 1 and 2
    Why o why did they fit a slot in it then :thumbsdow
  4. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +975
    The odds are that your aerial isn't upto the job, not having access to BBC1/2 is unusual though it's normally ITV, Five that are missing.
    The TWIN wasn't designed for TUTV, it was initially specced for ITVDigital and obviously the embedded CAM is hardwired in such a way that it can not be upgraded to support SECA2.
  5. LV426
    LV426
    Jul 14, 2000
    13,317
    +5,669
    Check on www.dtg.org.uk to find the UHF Channel number that carries digital BBC1 and 2 at your transmitter. Then check to see what aerial type is needed.
    Ensure that nothing else (such as a VCR) comes in between the aerial downlead and the Twin. Check that your VCR (if you have one) isn't set to output RF on the UHF Channel number in use for BBC1 & 2.
    Consider changing your aerial, if necessary.
  6. andyMallion
    andyMallion
    Thanks nigel
    I've been on the roof and tweaked the aerial, fitted a mast head amp and all the channels are there :thumbsup:
