Pace Twin Survey - Earth Fix / Hard Drive Upgrade
Discussion in 'Satellite TV, Sky TV & FreeSat' started by lscolman, Mar 20, 2005.
  1. lscolman
    lscolman
    Jul 31, 2003
    7,145
    Tyne & Wear
    +151
    I've owned a Pace Twin for a few weeks now, and noticed that Channel 4 recordings were problematic. The channel would breakup when both tuners were on Channel 3 or 4 (same Mux). I also found that recordings would fade to black, but sound continued. I performed the earth connection across the tuners, as shown here...
    http://img.photobucket.com/albums/v32/turbolag/PaceBoxMod.jpg
    This appears to have solved the problem, but will report back on this thread.
    I'm now interested in a hard drive upgrade to a 60Gb Fujitsu. The original drive is the newer drive, which is the MHT2020AT. I plan to put in a MHT2060AT, as these can be bought for just over £60 inc delivery from www.microdirect.co.uk.
    I've read countless posts about the Pace being problematic, but this appears to be the case with any PVR, so I'm going to stick with it. The picture quality is excellent, and I can confirm this after owning most of the high end Freeview boxes.
    I'd be interested to hear comments from other owners who have either the MHT2060AT (60Gb) or MHT2080AT (80Gb) drive fitted, and have performed the earth fix, can you reply to say whether there are any futher operational issues you have encountered.
    Thanks in advance
    Cheers, Lee
  2. Brava 210
    Brava 210
    Feb 17, 2005
    2,610
    Bristol
    +1,006
    i fitted a mht 2080 in my pace from pcnextday £68 and also done the earth mod
    changing the hdd was very easy and has not affected the machine at all, it gives me 43 hours of recording.......
    :smashin:
    Gary
  3. lscolman
    lscolman
    Jul 31, 2003
    7,145
    Tyne & Wear
    +151
    Hi Gary,
    Thanks for that.
    A couple of questions if I may...
    How long have you had the new drive fitted, and is it a MHT2080AT?
    Cheers, Lee
  4. Brava 210
    Brava 210
    Feb 17, 2005
    2,610
    Bristol
    +1,006
    had it fitted about a month,yes it is mht 2080 at
    works a treat,i seem to get less glitches now than before......
    Gary
  5. lscolman
    lscolman
    Jul 31, 2003
    7,145
    Tyne & Wear
    +151
    Anyone else with a similar setup?
    Cheers, Lee
  6. davidyoung
    davidyoung
    Had a pace twin for 2 years now - all the usual bugs. Performed the earth mod, seemed better for a week, but now its back to normal. Back to the drawing board!
