Pace Twin Software Download Now
Discussion in 'Digital TV & Video Players & Recorders' started by Richard46, Oct 20, 2003.
Tags:
  1. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    Just in case any one had not noticed new software should have been avilable since 10.00am. Its only there for two days. Not had time to get it myself yet. You need to have the Twin on a BBC Channel.
    Regards Richard
  2. Pottsy
    Pottsy
    Apr 15, 2003
    288
    Leicester
    +6
    I notice the splash screen has loads more contrast. Is it my imagination, or do some channels seem to have more contrast too?
  3. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    I think your right, is the picture sometimes a tad darker as well?
  4. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    The dark output is very noticable and quite irritating
  5. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    Its strange that they have adjusted the picture as most feedback about the picture seems to have been positive since the soft picture problem was addressed a couple of downloads back.
    Its not as if they didnt have things that did need work. I will mail pace asking they revert to the previous settings in the next software version. (assuming they havent lost them).
  6. Pottsy
    Pottsy
    Apr 15, 2003
    288
    Leicester
    +6
    The dark output on mine seems a bit random, and comes with the increased contrast. Can't find a common thread to it. Bizarre!
    I too would like to go back to the old picture. But it hasn't crashed when flicking through channels yet, which is good!
  7. jjcool
    jjcool
    finally got mine and very happy with it.
    anyone know if i can record off my cable box thats going into the pace box??
  8. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,815
    Somewhere in South Yorkshire
    +5,023
    Pace Twin cannot record any external sources.
  9. jjcool
    jjcool
    seems im getting hit and miss picking up the channels, 1 time i will get 43 channels another time 32 and another time only 20!
  10. LV426
    LV426
    Jul 14, 2000
    12,815
    +5,023
    Indicative of a poor aerial signal and/or occasional reduced power from the transmitter.
  11. jjcool
    jjcool
    would a Ariel
    booster work?
  12. LV426
    LV426
    Jul 14, 2000
    12,815
    +5,023
    That depends on what is wrong with the signal (assuming that that IS the cause).
    If the signal is 'dirty' i.e. contains interference picked up from the downlead etc, or multipath problems (you'd see this as 'ghosting' on an analog signal) then an in-room signal booster will amplify the problem as well as the underlying signal and won't cure the disease.
    You may need either
    - a new aerial, more suited to the frequencies used for freeview muxes
    and/or
    - a masthead amplifier to boost the signal BEFORE it goes down the downlead.
    However, before embarking on any of this - check your cabling. Ensure that the FIRST or only thing the aerial cable goes into is the digibox. Ensure that the cable isn't damaged and that all the plugs and sockets are in good order.
    If that doesn't improve matters, you should get a good local aerial contractor to advise.
  13. marksm74
    marksm74
  14. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    Thats odd, much shorter gap than usual between updates. I womder if this is at least partially a reversion to a previous version, as the last version seems to have caused as many problems as it solved. My Pace has had few problems before but since last week I have had a couple of weird things.
  15. marksm74
    marksm74
    They've now updated that webpage to say that this is a repeat broadcast of the 20-22 October update, so nothing new I'm afraid. That one was only 47 hours so I suppose that's why they're making it available again so quickly.
  16. Sunil
    Sunil
    Apr 27, 2003
    93
    London
    The 20 October update made my Twin much worse than it was before. It was 90% reliable before it, but now I'd say 50%, because I've had quite a few recordings that only playback upto half-way through.
    I'm going to try to reload the update tonight and see if it makes any difference...
