Pace twin reception problems
Discussion in 'Satellite TV, Sky TV & FreeSat' started by stevewal, May 7, 2005.
  1. stevewal
    stevewal
    Hi all just after some advice please.
    Ive been using an old nokia ondigital box for the last few years to receive freeview & had no problems with the reception & received all the channels even though the signal strength was poor.
    Ive just got a pace twin recorder but im now only receiving 6 channels (mainly bbc) & the signal strength is 6%, which is poor but it seemed to be enough with the old ondigital box?
    So do different boxes work at different signals strengths? do you think i need to upgrade my ariel to a high gain type? If so what could anyone recommend?
    Been looking at a Triax Unix 52 which are available on ebay for £20.
    Any help would be welcome.
