I have just had a problem occur with my Pace Twin, while watching live TV the picture froze up, but the sound carried on as normal.
No buttons on the remote or the unit would do anything, in the end I had to pull the plug out of the back.
I had a similar problem while playing back a recording, except that the buttons kept working.
After stopping the playback and turning the unit off then on, it all worked ok.
I downloaded the latest software a couple of weeks back.
Should I return the unit as faulty?
And if I get a new unit will I be able to update the software to the latest?
Skiddins
Skiddins
