Pace Twin - Can signal strength be shown ?
Discussion in 'Digital TV & Video Players & Recorders' started by mjw123, Jun 3, 2004.
Tags:
  1. mjw123
    mjw123
    Apr 21, 2004
    1,302
    48
    +32
    Seem to be getting ocassional judder / freeze on ITV / C4 / C5.
    Is there anyway you can see on the twin the strength of the signal that each channel is receiving via the aerial ?.......i'd guessed you'd need another device to do this.
    I have recently had a high gain wideband installed but it looks like a booster may also be required bhut will wait till the update has been applied in case that helps.
    TIA
    Mike.
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,554
    Somewhere in South Yorkshire
    +6,055
    Yes. Look in the menu.
    You need to be concerned with TWO factors - strength and bit error rate.
    A strong signal will still display glitches if it is interfered with to sufficient an extent. A weak signal, which is totally clean, will display a good picture and sound.
    A weak signal, however, will be more susceptible to interference (and hence, being "dirtied").
