Pace Twin - can it record inputs?
Discussion in 'Digital TV & Video Players & Recorders' started by Bearded_Malc, Aug 11, 2004.
Tags:
  1. Bearded_Malc
    Bearded_Malc
    Aug 10, 2004
    393
    +20
    The Pace twin manual I snagged off the net says
    TV SCART . . . . . . SCART (composite video in/out, RGB in/out)
    TV2/VCR SCART .. . SCART (composite video in/out, S-Video out)
    Which I think says is has video inputs, does it? Can it record them? Or can you only record freeview programs?
    TIA
  2. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    It can only record freeview off the air.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,526
    Somewhere in South Yorkshire
    +5,999
    .....and the inputs are there for loopthrough purposes only. It has no onboard ability to generate the digital (mpeg2) code from any external source. It can only receive what's broadcast and place it, unchanged, on the hard disc (or convert it to analog for output to a TV or VCR).
  4. Bearded_Malc
    Bearded_Malc
    Aug 10, 2004
    393
    +20
    How does loop through work then? Can I RGB from DVD player to Pace Twin and then RGB from Pace Twin to TV? That is save a TV input.
    And if I do that how do I select the TV source or does it just loop through when in standby, which would disallow watching DVDs which recording if it was wired that way.
  5. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    It loops through and uses RGB Sync on Composite
    I loop mine through the DVD player, some people loop DVD players through theirs with RGB.
    You can turn off while recording.
